Big Bike Thread
Status
Not open for further replies.
used to get loads of punctures on maxis crossmarks, switched to specialized armadillo elite tyres and have had 1 puncture in 9000+miles and that was a mutant huge thorn-nail heh
next time it punctures slowly/gently run your fingers around the inside of the tyre until you find what caused the puncture and be reluctant to fit a new/fixed tube until you've found what caused it.
Yup, although designed for road wheels mainly the hubs will take a 15mm kit (ukbikestore sell them) and the pro 3 sp-am4 takes a 20mm kit. :)
Why do people say pro3 hubs are designed for road wheels? mine are light MTB wheels and are specific sold as so. And stated on the hope website as lightweight race wheelset.
ooooooooh really...?
Does this refer to the Pro3 or Pro2?
What I posted was regarding the Pro3 hubs.
Added a new bashguard:
Straitline 32-34 serrated, I have the 12 sided one on my HT.
Cheers dude :D Nothing I really want to change/upgrade now, keep thinking I should get some 'proper' (lawl..) forks but they're working so well at the moment.
You wont have to pay any tax because it's in the EU. :D
I'm away to do some work on a pals old Big Hit and noticed some what looks like cracks (1 at each side) in the FSR rocker link:
Replace or ok?
Couple of sheets of newspaper :p But I too get a cold stomach/chest typically, even with say a HH base layer, I tend to wear my gillet over the top.
Sounds like you need a colder rated base layer,
I tend to only wear HH "Dry" Striped crew and an Altura Night Vision jacket.
If its really cold I'll also wear a cycle jersey of some sort, but will normally tend to take my jacket off then as i'll get too hot.
I rarely get that cold as i'm fat ! it has its uses !
Definitely! It's on my to buy list for sure!
Status
