***DEAL OF THE MILLENIUM - MSI GTX 470 Twin FrozR ONLY £143.99 Inc. VAT!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I think right now our competitors are literally face palming with these deals were doing, so check this one out:-
MSI GeForce GTX 470 Twin Frozr II 1280MB GDDR5 PCI-Express Graphics Card @ £143.99 inc VAT
Key Features
- Twin Frozr II Thermal Design - Reduces Heat by 16C and Noise by 21.5dB
- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.
- Five heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
- Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- All Solid CAP for longer lifespan.
- Over voltage function of GPU
- Supports over voltage function of GPU by Afterburner, and performance can be up to 15%!
- PhysX & 3DVision Surround technology
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience. (3D Vision surround for 3 monitors require 2 cards running in SLI mode to work. Need to work with 3D monitor and 3D glass.)
- Specifications
- Voltage Tweak Technology
- Twin FrozR II 5 Heatpipe Dual Fan SILENT Cooler
- Extreme OC Potential (Voltage tweak, Military capacitors, uprated cooling)
- Core Clock: 607MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3348MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1215MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was [£199.99] Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Our competitors are all around or above £200 for this same card, were over £60 cheaper, in percentage terms that is nearly 50%, yes OcUK nearly 50% cheaper. THIS PRICE IS PRE-ORDER ONLY and stock arrives Friday, on Friday we shall increase the price by approx £10-£15 still making us over 30% cheaper than anywhere else or a good £40-£50. :D
Now that is sweet. Even better than the two I got for £165 each.
Well done.
ANybody who hasn't upgraded recently would be mad not to buy a pair of these.
For under £300, gtx 470's in SLI destroys the competition.
£60 off £200 is 30% cheaper not 50% :P
OK so currently I have one of these running under water on a HX750. Would it be ok to stick one of these in on air, and will the PSU power it?
Hehe good question Fox, I don't know, it's not an easy choice, both will demolish my GTX 260, both are great deals ...I don't need the extra power of the 480, but there is just something about the idea of having that card that makes me smile. I really don't know what to do now. I would like to keep the nosie and heat down though.
[TW]Fox;18363189 said:
Hmmm. This or the 480?
I'm in the same boat, I've literaly just got a samsung 2233rz monitor so I'll be gaming in 1680x1050 for a few years yet - that swings it to the 470 for me :)
I would say this, if only for the incredibly good cooling it has, once overclocked you're not going to notice the performance difference between it and a 480.
I've got a 480 on order, but thinking about 2 of these. Only thing is my PCI-E slots are close together so I'm wondering how temps will be....
Now that common sense is starting to kick back in I am leaning towards the 470 tbh, saving 50 quid, better cooler, quieter, cooler running, probably overclock nicely should I wish and in all honesty I doubt I would use all the power of a 460 much less a 480.
Unless you overlock the 480 that is:).
Both are great deals. The 480 has 20% more VRAM/bandwidth plus a few extra shaders/ROP's. It may also overclock slightly better due to 1x8 + 1x6 pin connectors but is it worth £50 more?
I guess that extra memory may come in handy for those who game at 1920x1200 or higher, but 1920x1080 and below probably won't notice much differene.
How would this compare to a 5850? I can overclocked the 5850 to 950/1150. Any advantage in upgrading here?
Main use will be FSX which is rumoured to prefer nvidia cards.
