If your data is so important, you'll have you multiple backups which you verify and test on a regular basis, so an HD failing shouldn't be an issue, should it?
If you have "accepted" the goods then you lose the right to rescind the contract (essentially cancel it for a full refund) if the goods are not of satisfactory quality. You have accepted the goods if you tell the retailer that you have done so or otherwise make them believe that you have done so. There is no specific time limit, the Sale of Goods Act just states "The buyer is also deemed to have accepted the goods when after the lapse of a reasonable time he retains the goods without intimating to the seller that he has rejected them." "Reasonable time" could be anything from a few days to several months depending on the nature of the product and it would ultimately be up to a court to determine it if it came to that.
But even if you are deemed to have accepted the motherboard, you are still entitled to a repair or replacement if it develops a fault that was due to a manufacturing flaw.
I would be more concerned about someone buying a motherboard today - if they have been made aware of a particular fault prior to the purchase then they may well lose their statutory rights in regards to that fault...
Exactly. And the fact that it doesn't kill HDDs![]()
Ever tried moving TBs of data about?If your data is so important, you'll have you multiple backups which you verify and test on a regular basis, so an HD failing shouldn't be an issue, should it?
Please back this statement up with evidence, as far as anything I've seen there has been no one promising there will be no risk to data.Exactly. And the fact that it doesn't kill HDDs![]()
The issue of degrading performance and possibly even data corruption over time is seen when using the SATA II ports on motherboards that are powered by the Intel P67 chipset.
When you lose data then you are temporarily without a backup, making a new back up with limited ports is also going to be more than a little time consuming and inconvenient. Since a lot of that data is personal rather than commercially valuable I don't have the cash to throw at going as far as multiple backups, hence worrying about prevention such as using a SATA port that may or may not trash my data.
Looking around all the reports avoid making definitive statements except for tweaktown that have stated data is possibly at risk.
http://www.tweaktown.com/news/18701..._and_the_aussie_flood_dream_system/index.html
Can someone confirm that ONLY motherboards manufactured AFTER January 9th are flawed? I just read this in an article.
I managed to get my P8P67 Pro early and had it a week before release.
Yes, ASUS P8P67 PRO with i5 2500k, GPU and RAM purchased from yourselves. Last system + upgrades also were purchased from OcUK.
If you still don't believe me you'll also see I posted regarding the Titan Fenrirs not fitting that motherboard, and the troubles finding a cooler that allows you to keep all 4 RAM slots available considering the height of the Vengeance RAM.
So cutting to the chase, are you guaranteeing as a representative of OcUK that there is no risk of data loss associated with this issue?
Insinuating that one of your customers is a liar has rather knocked my opinion of the supplier I've been using for 90% of my computer purchases for the last 5 years. I had been impressed when I had to return the Fenrir but now![]()
Classy.Stop being soft, I never called you a liar.
There is a lot of people on here who love being part of the "get offended on behalf of everyone else" crew. Glad you are not one of those people.
I'm being pedantic because I'm concerned about possible data loss and the downtime that will be caused if it occurs. Also the general vagueness of the reports make me suspicious as the only people saying don't worry your data isn't at risk are people in this thread.Your posts were coming across very pedantic. Anyways I checked your post history before you replied.
