Indeed but the rest of us have to!
I'm referring to pedal bikes in case you're talking about cars/motorbikes. Standard example would be the 3 way junction whereby cars actually do not change speed or direction and i just move along side + also empty but still red on some roads.
I hit you and mash up your bike... You'd claim off me Im sure.
You hit me and scratch/bash up side of my car... I claim off who?
You hit me, it might be my fault or yours. If its mine then i'll try to get out of there, walking, if the bike is totalled. If its your fault then i'd except cash to replace/fix bike and settle it.
If i hit you, and my bike is working, id just cycle away.. tough luck, give more space next time, nobody on a bike intentionally wants to crash into a car because bikes damage easily.
What narks me is the amount of cyclists Ive seen in newcastle with no hi-vis gear on, no lights and no helmet skipping back and forth from road to path when they see fit. Aren't you meant to have a helmet on in order to use the roads?
On top of which the blatant disregard for lights because " I can fit thru that gap" an the random path/road hopping because "cba to wait on lights" will make you Im sure at least a little more likely to have an accident
[/QUOTE]
I don't need high vis as I am in London there are a ridiculous number of street lights,
if someone cant see me they shouldn't be driving and that's that.
I agree with you that people should not cycle on the pavement, i never do that.
As for lights, it doesn't make it more likely to have an accident, there is very little risk to everything i do, you and others think its risky or dangerous when its not
One incident i remember is this, guy on right lane turns into road on left, cutting me off completely (he did not even signal, and fyi traffic lights were green)... What happened is that i slid along the car, as he was turning, and im turning with the car, eventually he stops, i cannot stop in time, i smash off his side mirror with my hand guards (not intentional).
Then im like *************.. Then i cycle off.
