How did people do the end boss? I've got practically no ammo!
Ha! Tell me about it, my first run through I got to the final boss with 2 cans of flamethrower fuel and that was it...
Best thing to do, is wait for loads of the shadow things to appear, then kill you know who, when you know who dissapears all the shadow things die automatically and drop a ton of stuff. Run round and grab it all, and repeat a couple of times until you have enough ammo.
It's a right pig.
My 2nd run through I knew what was coming so I stocked up on ammo, and ran through most of the rooms leading up to it as you really don't need to fight them all, and the boss fight is soooo easy when you have ammo, took about 10 shots of the Seeker Rifle and about 20 seconds and it was all over!
BTW - Advanced Elite Suit = Carbon Fibre Godliness!
I'm currently using the node glitch to power up everything. There's now way i'm going to play through it enough times to power up properly. I'm only doing 4 weapons so have opted for the plasma cutter,ripper,pulse rifle and force gun.
It takes less than 2 runs to power up.
By the end of my first run I had max RIG, max Stasis, and maxed out 2 guns with nodes to spare.
I'd maxed 2 more guns on my 2nd play through within a couple of hours.
Much more fun than save/reloading over and over...
By the time I finished my 2nd run through I had nodes coming out my ears
Anywho, i've now got 45/50 achievements, 2 I can get easy tonight, 3rd is a bit tricky (not missing any of the things climbing on the lift to the solar array), and the other 2 I can't be bothered with atm (Zealot and Hard Core).
