Piercings on guys
I think chicks with piercings are pretty hot, not too many, but maybe a nipple and a lip.
As for guys, some suit the ear piercing, the footballer with spikey hair look, but most i doesnt suit.
I'd like to get my left ear pierced just to try it, doubt i'd suit it though.
1) navel piercing: Only get it if you have a very toned stomach or you will look an idiot. And ring not bar after all you are male
2) eyebrow, my first piercing was my eyebrow (it grew out within 12 months as I had quite a heavy bar in there) make sure you use a light weight piece of jewellery if you want it to last
Those of you who are joking about the Albert are just jealous or wimps.
Let's have a look.
:p
I'm fairly open minded and I've gotta say a belly button piercing on a man could only work with a hefty limp and a pink t-shirt that's 2 sizes too small.
Right, I have been using hot salt water to clean my piercing, but it has got a bit sore over the past two days or so, and it a little red, what is the best way of using the salt water to clean it?
i have been using cotton buds and balls and dribbling it over the piercing and wiggling it slighty to get it in there. But as I say, its a bit red and sore...
vodka will sort it out, failing that just drink the bottle then the soreness wont really be an issue,
I have two piercings in the left ear, one stud and one hoop. I used vodka to keep them clean, they healed in no time at all and look clean/rot free :)
It's a piercing that's in a very awkward area to heal, so it'll get red. Don't wiggle it. Just get a small glass, fill with warm slightly salty water and put it over the piercing. Soak it for a couple of minutes then wipe any excess crusty stuff off.
It's my eyebrow...
right...I don't understand why a guy would get that done...
See above...
