Big Bike Thread
Status
Not open for further replies.
There is no way I could use that up here. In fact even my racing buddies don't even use that.
Go back to your road bike...weirdo :p ;)
Up where?
I did all of 7stanes + Laggan and didn't use the granny once.
For sure some off piste stuff can get steep but I bet you find that 36 too low.
Up where?
The trails I was thinking of were some in the Cairngorms (Firmounth long & Mount Keen) and the impossible climb at Pitfichie. There is nothing that steep in the 7 Stanes or laggan. Also I'll be using a 30lb AM bike. I run 11-32 on the XC bike.
got my avid caliper mount bolts this morning and thats sorted my calipers out :D
anyone else had packages from CRC? i got the bolts in a box A4 sized if not larger, and yesterday i received a chainstay guard in an A3 sized box seriously wtf? :confused::p
I got my Sombrio gloves in a box the same size as my original Xbox 360 came in. Yet when I bought my new seat, the box was rather small, and it was broken because the seat had been forced in.
Strange people up at CRC. :S Brilliant service from them so far though :)
Speaking of deliveries :D
im just finishing off setting my bike up and am working on the gears at the mo and need opinions on the rear loop i have near the rear mech.
does it look too big? or just right :confused:
Doesn't look to bad, personally I would make it a little tighter just to reduce any chance of catches. Jagwire sticker on the frame though no don't do it! How are the superstar wheels?
yeah the sticker is going to come off soon :p
ill cut another bit as i was concerned about catching as well, havent had a chance to test out the bike properly yet as im recovering from an eye op but hopefully next weekend :D
anyone else trying the alligator gold ti ni discs, they look the biz :D:D:D
What are the little screw ends called that limit how much pressure can be put on the lever? I fitted some new lock on bar grips yesterday and had to remove them as the grip ends are too wide. I need a thinner "screw end".
looks too long if it's a slx "shadow" type, or too short for conventional, either way it looks wrong or maybe just odd camera angle?
Status
