Windows 7 key identifier?
23 May 2006
Hi
I have a legit windows 7 key however i have no idea what sku it is for, is there any software or any way to find out?
All i know is it is not windows 7 64 bit professional, it MAY be 64bit home premium but i do not want to download and burn the iso wasting time, bandwidth and a disk if it isnt going to work.
Are there any disk images i can use which will work with ANY LEGITIMATE 64bit keys? i was told that there is one but i cant find it
finally, is there anyway i can convert my windows 7 64bit professional install to a version which my key will work with without blapping and reinstalling, i am currently on my free 30day evaluation period and if i can get away without a reinstall i will do
thanks
Mike.
PS once again, this is a legitimate key not an illegal one.
If you use a retail disk, it's one disk for Starter, Home Basic, Home Premium, Professional and Ultimate. Entering the key during setup automatically chooses the right product.
If it certainly isn't Enterprise (and it won't be Enterprise, you'd just know), then you should be able to just use a retail disk.
no it doesn't. you've obviously forgotten the fact you had to modify your ISO for you to get a choice of editions like that.
ahh ok, mine must be an upgrade disk then as it does not have those options.
i will get hold of a retail one then, thanks
edit
thanks marc, i will have a go at editing my iso then :)
so will it automatically choose the right one by me putting in my key (as i do not know what my key is) or will it be trial and error till i get it right.
use the eicfg_removal_utility.zip from this page: http://code.kliu.org/misc/win7utils/
and yup, trial and error will get you there. if you choose an edition and it refuses the product key, i think you might be able to hit the back button. if not, you'll have to restart setup.
but having a legit key and not knowing which edition it's for does look a little suspicious to me... :D
lol suspicious maybe but it is a legit key, if not i would just get a crack off somewhere and be done with it.
PS the irony... a capo accusing a gangster of possibly breaking the law ;)
I've worked on several laptops that just have a microsoft sticker and a windows key, no mention of what version of windows they're actually for.
thanks for your help guys i used eicfg_removal_utility.zip on my windows professional which failed my key and got it right on my next attempt. My key is for home premium
so i now have Win 7 professional on my media PC and home premium on my gaming rig.
Am not sure it makes much difference but i guess i will look into it and see if i should swap them around.
cheers
M.
PS as an aside, i am currenlty without internet till the 17th as am in middle of changing providers. BOY what a pain in the backside setting up a pc without internet.!!!
