- 10 Nov 2003
- Surrey, by the river
Far as I'm aware halfords have an exclusive agreement with Boardman.
Where from?? I've been told my 54cm Black Super Six 105 wont be in till June! No one can get hold of any. Evans have team in 54 but i want black, all my my bikes are black & white, call me a tart i dont mind!
Looks like there was a massive hill near the start, was it tough?!
[DOD]Asprilla;18420303 said:Hang on; you're going to have a Super Six, a Synapse and a Madone 6.9? Surely there isn't that much difference between those bikes?
I'm aiming for my stable to be my Bryant tourer, Cervelo S1, Cervelo RS and a Cervelo P3 but they are all radically different geometries and materials and have very different uses.
I'm thinking of getting a shorter stem for my road bike and going from 110mm to 90mm as, having spent more time on the bike recently, I feel too stretched out. Are there any drawbacks to going for a 90mm stem?
What device are you using?There will be errors in the elevation, I can't see there being a 900ft ascent in one got round there, best to check elevation correction to "enabled"
Some rides I get back it says 13,000ft, then I click "enabled" on elevation correction.... 7,500ft...![]()
Activities recorded from devices without a barometric altimeter are enabled with Elevation Corrections by default. Alternatively, activities recorded by devices with a barometric altimeter generally contain accurate elevation data and therefore Elevation Corrections are disabled by default.
Got nicely t-boned by a Mercedes on the way to work yesterday.
Lucky escape for me - no breaks but plenty of bruising and sprained neck, but haven't been able to inspect the Orbea yet. Definitely needs new handlebars but need to check the frame etc. for damage. Am I right in assuming Carbon is more fragile in situations such as this?
think I'll order one of those cams if I start road riding.
anyone got a reccomendation
Next time I replace my chain I want to use a chain which I can take off the bike to clean. Currently have a 10 speed Campagnolo set-up, what would everyone recommend and is there such thing as a reusable link?
