~~~~~DEAL OF THE CENTURY MK2 - 4GB 1600MHz CAS8 Kit ONLY £25.99 Delivered (PRE-ORDER PRICE ONLY)!!!~
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well I am running out of title names for my epic deal threads, so first of all some statistics:-
  • 4GB Kit (2x2GB)
  • 1600MHz Frequency
  • CAS 8-8-8-24
  • 1.55v-1.65v operating voltage
  • Sandybridge compatible (run at 1.55v, may have to slacken to C9)
  • OCZ Special OPS / Black OPS heatspreaders
  • Lifetime Warranty with OCZ / OcUK
  • CHEAPEST IN THE UK FOR A 4GB KIT, then add in the fact this is 1600MHz and C8, we've just dessimated our competitors!!!
  • £25.99 Inc. VAT PRE-ORDER ONLY PRICE UNTIL FRIDAY!!!!!
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) @ £25.99 inc VAT
Featuring the high densities and stability gamers demand, these DDR3 kits are ideal for users advancing to the next generation of memory platforms, offering the speeds, density, and reliability required for the latest DirectX 10 PC titles. Featuring a unique camouflage motif heatspreader design, the DDR3 Special Ops Edition Series was designed for gaming systems in need of a reliable upgrade as well as some extra style.
The PC3-12800 SOE is available in 4GB low-voltage qualified dual channel kits for the high densities demanded by graphic-intensive games, operating systems, and applications. The Special Ops Edition is the ideal solution for gamers who need high density options in addition to superior reliability and bandwidth management without the hefty price point. These modules offer the stability and speed to give gamers the performance edge with a highly reliable, future-proof system that takes advantage of all high-speed DDR3 has to offer.
100% Hand tested for quality and the unbeatable lifetime warranty will contribute to your peace of mind during even the most intensive gameplay!
Specification:-
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- Available 4GB Dual Channel Kits
- Unbuffered
- Special Ops XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240-Pin DIMM
Was [£34.99] Inc. VAT
Only £25.99 inc VAT - PRE-ORDER PRICE ONLY UNTIL FRIDAY!!!!! - CHEAPEST IN THE UK!!!!!!
ORDER NOW
It does not get any better than this, our competitors are asking between £35-£45 for lower performance C9 kits and in some case nasty un-branded cheap rubbish. This is OCZ, CAS8 with lifetime warranty a good £20 cheaper than it should be!!! :)
2 of them ordered for me...yeah.
I ma starting to wonder if Gibbo has infact been made redundant and is trying to destroy the company before his notice is served........anywaysm keep up the great deals Gibbo.
Not bad not bad, finally starting to see DDR3 hit the bargain prices we were seeing for DDR2 a couple of years ago (<£8/GB). Good for anyone upgrading but I think I'll hold fire until we see some deals on faster 8GB kits, don't fancy filling all the memory slots especially as I'd have to drop from CAS7 to CAS8.
Can anyone tell me what the difference is between this and the OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz memory kit? I know these are cheaper and faster than the platinum gold.
As you say, these are faster and cheaper. The Gold (incl Special Ops) series of DDR3 modules seem to be more prone to failures than the Platinum series. Quite a few user reviews report DOA modules or modules that fail later in life. Best to run a few loops of memtest on these as soon as you get them, but I am sure OcUK will cover any issues.
NOW SHOWING IN-STOCK
Thanks! I originally had the platinum gold kit ordered then I seen these the other night so I just quickly cancelled and ordered these. Got email today they are shipped!
But after reading your reply, uve got me worried.
Will do a memtest (never done it before).
Building a new system after like 3years lol. Got myself a gigabyte 1156 pa55-usb3 motherboard along with an icore 3 540 3.06ghz and plus 8gb of ocz ram.
People who have problems are always more likely to post comments. These should be absolutely fine (I have oredered 3 sets), but they do seem to have a higher failure rate than is usual for OCZ.
I ordered 2 sets as well for the new build, but I can see RMA being lots of fun with OCZ pulling out of the memory market
The first year is covered by the retailer (OcUK), but after that you will most likely face problems. Saying that, OcUK do state a lifetime warranty for this product and there is no limitation clause.
I'm currently running ocz 1600mhz tri channel 3x2 sticks 6gb.
Would It work If i bought 12 gb of this stuff and ran it in triple channel mode?
