Handling is horrible.
well if its the same melody "every game is a sim" then yes it is terrible which it isn't really.. im playing it happily on hardcore settings with wheel.. and its fun.
Handling doesn't seem that bad to me although I'm playing on hardcore with a wheel as well.
how on earth do you remap gamepad buttons wont let me deviate from the 360 default after i used a 360 pad emu in order for my rumblepad 2 to work.
It might be diff for a wheel but defiantly on a pad the handling is seriously bad really really jumpy.
Also graphics to me they look fine, not amazing but good enough, the framerate though is shocking! consistently less then 30fps.....all max,2aa 1080p
I've not had any joy with the clutch on the G25 - there's an option in the controls for it, and it defaults to the correct pedal when you select the wheel, but as far as I could tell it didn't make any difference at all to changing gear.Does this game have clutch support for g27?
