Big respect to you for trying something of this calibre mate, subbed!
Can't wait to see the final outcome
 Thanks nayan89.
			I want an IO/pci bracket machined from billet.
 Looks so nice, but £200 is better spent! Will be really interesting to see how the layered PCI&I/O plate comes together.
Good work brushing the aluminium - looks VERY nice. What did you use for it - sandpaper/wire wool?
They look bada$$, only seen 1 but yeah it was awesome
, for brushing the alu I used satinising mops, pretty much a polishing mop but like wire wool they are excellent for cleaning up messy alu brushing & many other things
Update
This was going to be an update earlier but got cracking on with an alternative so it wasn't a wasted day
LOL didn't go to plan :facepalm: the metal work did but the 5mm acrylic pieces didn't it's just soo brittle so came back in to get my thoughts together & as usual came up with an alternative which is all aluminium & if that fails then I could always go with a pci/io piece from another case & admit defeat on making my own but I'll give it another try but yeah that means loads of marking up again which takes a while to do right.
So the new plan is 5 3mm pieces bolted together, got 1 done & checked the IO cover from my last mobo & it won't go in easily because of it being 3mm instead of 1mm thick so to fix that all I need to do is give it a bevel on the last piece so the notches of the IO cover can click on.
Anyway the marking up will be nice & fast actually as I have 1 of the pieces made & it's spot on so it'll make a good template even for the 1 with the slots so back to it I go
 included the failed acrylic pieces for a laugh, the 1st 1 when drilling ripped a corner off & the 2nd 1 was going ok & cut out the IO piece but the reciprocating saw melted the cuts so wouldn't fall out & with already being frustrated with the 1st piece I whacked it out & it ripped it in half lol.
Hopefully I'll have some more pieces done by the end of the day, especially the 1 with the slots.
Started off positive.
Metal work went well.
Hmmmm acrylic pieces
Last try but this time all alu
Alright, got the needed pieces marked up in about 15 minutes thanks to the piece I already made, time to cut these out & even with getting them done as fast as possible it took 4 hours to cut all these & they require a lot of filing, I'll just have to remember it'll be worth it lol.
Yeah they look rough as I don't know what but that will change after heaps of filing
