- 2 Apr 2007
- North Shields
just google the build number from a few posts up.
Will do! Thank You for your help! So no difference from the release on the 22nd?
Although its the same build number it might not be the same iso image, hopefully it is though so i dont have to download em again!
I used a program called RT 7 Lite to integrate SP1 into a Win7 DVD worked fine.
i'm not integrating it myself. instead, i shall be acquiring a genuine microsoft MSDN ISO when they inevitably get leaked about 10 seconds after they are published later on today.![]()
^that's the release candidate. you did not want to download that.![]()
Format and reinstall![]()
