new pc games help
16 Aug 2009
ive been away form the pc games for a while now i would like to know if my pc will be able to run the new games out there like crysis 2,dead space 2 ect if so would they be medium to low ?
SiSoftware Sandra
Computer
Model : Gigabyte GA-MA770-UD3
Workgroup : WORKGROUP
Host Name : mrjordan-PC
User : mr jordan
Processor
Model : AMD Athlon(tm) II X2 245 Processor
Speed : 3GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 On-board Cache : 2x 1MB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
Computer
Mainboard : Gigabyte GA-MA770-UD3
BIOS : Award (Phoenix) FA 04/09/2009
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.25GB DIMM DDR2
Chipset
Model : ATI (AMD) RX790 GFX Single Slot
Front Side Bus Speed : 2x 2GHz (4GHz)
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Total Memory : 4GB DIMM DDR2
Channels : 2
Memory Bus Speed : 2x 402MHz (804MHz)
Memory Module(s)
Memory Module : Corsair CM2X2048-8500C5C 2GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-18 3-23-6-3)
Video System
Video Adapter : ATI Radeon HD 4800 Series (800 SM4.1 625MHz, 1GB DDR3 1.9GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : ATI Radeon HD 4800 Series (800SP 10C 625MHz, 512MB DDR3 1.9GHz 256-bit)
Compute Shader Processor : ATI Radeon HD 4800 Series (800SP 625MHz, 1GB DDR3 1.9GHz 256-bit)
STREAM Processor : ATI Radeon HD 4800 Series (800SP 10C 625MHz, 1GB DDR3 1.9GHz 256-bit)
Storage Devices
Seagate ST3500418AS (500GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:)
SAMSUNG HD103SI (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (F:)
HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
JMZMDST 1UN05IJ4TM (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (E:)
Logical Storage Devices
Hard Disk (C:) : 466GB (NTFS) @ Seagate ST3500418AS (500GB, SATA300, 3.5", 7200rpm, 16MB Cache)
Hard Disk (F:) : 932GB (NTFS) @ SAMSUNG HD103SI (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
3.5" 1.44MB (A:) : N/A
Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (E:) : N/A @ JMZMDST 1UN05IJ4TM (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Peripherals
LPC Hub Controller 1 : Giga-Byte IXP SB600 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700 LPC host controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Audio Device : Hightech Information System HD48x0 audio
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Giga-Byte SB700 SATA Controller [IDE mode]
Disk Controller : Giga-Byte SB700 IDE
USB Controller 1 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 2 : Giga-Byte SB700 USB OHCI1 Controller
USB Controller 3 : Giga-Byte SB700 USB EHCI Controller
USB Controller 4 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 5 : Giga-Byte SB700 USB OHCI1 Controller
USB Controller 6 : Giga-Byte SB700 USB EHCI Controller
USB Controller 7 : Giga-Byte SB700 USB OHCI2 Controller
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : ATI SB600 SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Network Services
Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x86
Windows Experience Index
Current System : 5.9
Performance Enhancing Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
It will run those games, but not very well. You shouldnt be expecting much more than low to medium settings i think. Possibly on some less demanding games youll be ok. Maybe time to upgrade? :D
Nv 460 or the ATI 6850 then for GPU upgrade on that budget?
I went from a 4850 to a 6870, massive improvement for me.
Would look at trying to OC the CPU a bit if possible as well.
Same as, then a couple of months later dropped a Q6600 and clocked it to 3.2 and can run damn near everything on the highest graphics settings without a hitch.
dead space 2 is hardly a demanding game btw just thought i would let you know :)
and btw i get average of 120fps in ds2 maxed out on a 5830 overcloccked to 900 on core and 4400 on memory
