'This year' as in the last 12 (actually 10) months. Mayte.
Why didn't you say the past x months rather than 'this year' which clearly means 2011?
This thread has gone a bit depressing, everyone come and vote on the girls in the picture in general![]()
[TW]Fox;18483513 said:That thread is totally weird, I'll get flamed by the GD possee if I say anything in there but there is definately something odd going on, 5 women don't ask you to post a group photo of them on the internet so geeks can see which one is the hottest.
It always makes me smile when people try to suggest expensive cars are cheap to run for in the main the reverse is true. Lots of fuel, big tyres, big service bills, expensive parts, expensive repairs should they beed needed. Costs can be reduced and corners cut but if you use it daily, use it for a couple of years a car with list price of 50K (as an example) will have the running costs of a 50K car even if it cost you 10K usually.
Let's take the E46 M3,
The issue is that I don't believe that I am 'cutting corners' anywhere nearly as badly some people are implying.
* If my car needs something doing, I'll do it (albeit eventually).
* I don't run the likes of PS2s and CS2 tyres because they'd be 'wasted' on me. I'd rather spend less to get tyres that are more suitable for what I want (The Federals).
* Doing my own spanner work isn't something that I consider an issue.
* While I have no issues with using pattern/non genuine parts, but if it is beneficial for whatever reason to spend the extra and go genuine, I will go genuine.
Please don't go there. A work mate is willing to let his (recently stolen/recovered) E46 M3 go for a very reasonable sum of money. I'd be lying if I said that I didn't seriously consider it for a little while (and no, I haven't looked properly in running costs).
[TW]Fox;18483662 said:Err wouldnt they £10k+ to buy it not be a stumbling point![]()
[TW]Fox;18479133 said:Because of course the purchase price of a car is all that matters when judging affordability, right![]()
It was a Jap spec but it was a GZ with UK spec brakes and alloys. It was basically a UK spec without the heated leather seats and bonnet vent.
Come on son, come with me and vote on the photo, this isnt going well here![]()
There are few more differences between UK and Jap Spec than brakes/wheels/heated leather/bonnet vent...
Steel turbos / injectors / cruise are the only ones I can think of?
Care you throw your hat into the "'For the performance, Supra running costs are pretty cheap" ring?.
