the most practical card @ 1920x 1080
Well... I ran Crysis 2, I would say on average on a rez of 1900 x 1200, I get about 40-45 fps with 'hardcore' settings. I'm dreading DX 10/11.
like i said, never played crysis, but read that it was badly coded so very little could run it smooth? will this be the case with crysis 2 or will the higher end cards stand a chance of maxing it?
Since you included Crysis the only answer is a GTX580 as it's really the only card that can really handle it maxed out at a decent framerate, otherwise a HD6850 would be fine.
At 1920*1080 even a GTX560/GTX570 would handle it maxed out at decent frame rates
For most games you don't need more than a single 6950. However for Crysis (and the upcoming Crysis 2) there is NO single 40nm fab GPU able to handle it, not even GTX 580.
A single GTX 580? Not a chance, unless you mean 30-45 fps is playable. If you run it at 30-45 fps, and I run it at 60 fps, there is little chance for you to win if you duel me in first-person-shooting games.
15 fps really makes that much of a difference.?
Hmm should I be thinking of spending more on the card?
Performance is a bit better than that, more like 40-55fps here at 1920*1200, only drops lower when loading sections of the maps. :D
Zomg but soemone running at 120 FPS will WTFPWN U :rolleyes:
