that's not very specific. i'm sure any beta/rc versions would say that too.
right click the .exe file you downloaded>properties and check the details tab for the file version. it should say this...
6.1.7601.17514
yes !
6.1.7601.17514
That is the correct MD5 for the final x64 SP1 installer.
Make sure to run the command dism /online /cleanup-image /spsuperseded in a command prompt once you're happy with the SP1 install, cleaned up about 3GB of space on my system.
MVLS has the new ISO's on with SP1 integrated for anyone that uses VLs
you can install premium from a pro disk....
eicfg_removal_utility.zip - http://code.kliu.org/misc/win7utils/
then burn the modified ISO.
or if you use a usb key to install, you don't even need this tool. just browse the usb key and delete
sources\ei.cfg
