Thinking of replacing the power hungry GU10 Halogen bulbs in our office with some LED ones, they need to provide the equivalent amount of light (50watt). I found some but they're about £20 ea. is this the going rate for LED 240v bulbs?
As in they don't provide the equivalent light?
So what option is there for useful energy efficient light?
In total the lighting in the office uses about 600watts.
You can get these new low energy spot bulbs now, better then LED they have a "hidden" coil inside like the normal energy saving ones.
Light is bright but never as bright as Halogen.
Only other option is to fit the low voltage ones with transformers, as they are more efficient.
Only thing is with the cost of doing that, you could replace your existing Halogen bulbs for years I would have thought.
1W will add about £1.50 to your bill over the course of a year if it's on all the time.How much do these actually save money wise? I only like mood lighting so these seem good. But for home use do they actually save any noticeable money over just energy saving lightbulbs.
Say a 15w bulb running 6hours every day for a month over a 1w led bulb running the same time?
How much light do the LED GU10 bulbs put out compared to a halogen equivalent?
Some of the 21LED ones say equivalent to 20W - would that be about right?
