- 6 Feb 2004
- Wiltshire
Looking to replace my BB7's (203F/160R) with some hydros, and need some advise/help choosing
Currently looking at either the Shimano Deore M595 or SLX M665, with some superstar disc.
The cheaper M595 are suppose to be more powerful but the SLX's come with Servo-Wave which increases rotor clearance which i like the idea off (hate rotors rubbing slightly, which i have all the time with the BB7's because they need to be so close to the rotor to generate any power)
My only concern is that i've read mineral oil doesn't deal with heat very well and that sintered pads aren't recommended. This true? because What mountain bike actually recommend switching to sintered pads once the originals are dead.
Anything else in this price range i should be looking at? Want something reliable for mainly XC and some DH/AM riding. I'm 15 stone and there for a Hardtail.
Ah, weird camera angle
This is how a Shadow rear mech cabling should look:
If they are rubbing, then you've not aligned the caliper properly.snip brakes snip
Anyone had experience with Alligator I-links?
I have been looking to change the cables on my bike because my shifting has become slow after a whole winter of riding. I use Low-Normal which is particularly bad.
My current setup is standard Jagwire cable outers lubed with Rock'n'roll cable lube which I got on well with before I changed to Low-Normal.
I heard that going to some sort of sealed cable would improve things.
I did some googling and heard good things about the followings:
Alligator I-Links
Nokon
Gore ride-on
Shimano XTR
Powercorz
Jagwire Rip cord
I kind of have my heart set on Alligator I-Links as they look very good and are cheaper than the likes of Nokon/Powercorz.
However, I would like to hear other people's opinion before I go and spend £40 on some cables.
BB7's are superb when setup properly
But, if you're looking for relatively cheap, good performance hydro brakes. What about Formula? I'd recommend them anyday
K18's / K24's on a Hardtail are fine.
There's always the Hope line of brakes
Edit: Shimano brakes; personally I would never touch them. Every brake that I've tried from Shimano has been poor. No power, fading. Generally crap. Whether or not they were bled properly I dont know, but I won't be touching them. Others however, will say different probably.
Cheap brakes followed by the words Formula and Hope![]()
A set of K18's are £150... Do the math IC boy![]()
Alligator I-Links
Nokon
Gore ride-on
Shimano XTR
Powercorz
Jagwire Rip cord
Wise guyThat would be a stock clearance/sale price and due in stock on the 7th April if they do actually get some more![]()
Wise guyThere's always the Bay
£128 direct from formula !
Looks good, up and down the same path or different route? any pics?
