Win 7 SP1 gets dated?
RC1
For x64 the final is 903 MB (947,073,024 bytes) (size on disk) and has an SHA1 of 74865EF2562006E51D7F9333B4A8D45B7A749DAB
1 SP1 keeps failing (TRUST_E_NOSIGNATURE ).
2 Tells me to install System Update Readiness thing.
3 System Update Readiness thing says it's installed, but doesn't seem to run or do anything else.
4 goto 1
:mad:
1 SP1 keeps failing.
4 goto 1
:mad:
I read today, that there are a few prerequisites, before you try to install sp1. Make sure you install all the stuff it offers (important) before installing sp1.
For me, iv stayed uptodate with the updates, so my sp1 download is ony 86mb...
Popped into windows update and installed fairly quickly for me, don't think there's anything apart from rolled up fixes and some new bits for server 2008.
I have kept up to date too, and SP1 is only showing as 13.6mb for me, but I keep getting the same error TRUST_E_NOSIGNATURE.
Does anyone know if I have to do anything else with the System Update Readiness utility other than just click on it and let it install?
Installed SP1, on reboot it said it had failed to install, checked Computer -> Properties and it says I have "Service Pack 1" installed. Errr... yeah.
edit: I deleted the 100MB system partition when I installed W7, don't know if that makes a difference.
It looks like they are starting to patch the activation exploits. Lets see how fast it takes to get around this. [KB2484033]
kb971033 was released last July, in any case who cares about people who steal it. They should just release an update to format PC's :p
What hacks?
It will restore any system changes including uxtheme files but the old universal theme patcher will still work.
