Hi there
**SPECIAL PRE-ORDER PRICE ONLY**
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £197.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Revision 1: Flashable to 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Card Dimension(mm) 275*110*38mm
- Warranty: 2 Years
Was [£219.99] Inc. VAT
Only £197.99 inc VAT.
ORDER NOW
This is the lowest price by far in the UK on a top quality branded ATi Radeon HD 6950 with 2GB of memory. These are also revision 1 which means they are flashable.
I am doing this price *ONLY* until stock arrives or until we've sold the first 200 units. So ensure you get one at this price I suggest you order before Monday.
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
