STS-133 Shuttle Mission to the International Space Station Launches Thursday 21:50 GMT
I'm finding that the 1200kbps stream on page 1, althought it's better quality, keeps pausing the image for several seconds, so I'm just using regular nasa tv now which streams fine with no pauses (so far anyway)
Forget? Timer? You think I've not already got NASA TV on in the background? :D
PS - Using the lowest bitrate stream. There's no point using the higher bitrate streams until 'action' starts happening - which is about three hours away.
Are the launch times correct in this thread? It less than four hours tilll launch so shouldn't it be 1830 GMT? Am I missing something? ;)
It's at 16:50 EST - 21:50 GMT
I now assume the big countdown clock on the video stream is pre-launch then? :D cheers I got confused
What you are seeing is the real countdown clock with all its built in holds. These occur at T-27 hours, T-19 hours, T-11 hours, T-6 hours, T-3 hours, T-20 minutes, and T-9 minutes.
We are fast approaching the next hold, times in GMT (EST+5):
Enter 2-hour, 30-minute built-in hold at T-3 hours (15:25)
Perform inertial measurement unit preflight calibration
Align Merritt Island Launch Area tracking antennas
Complete filling the external tank with its flight load of liquid hydrogen and liquid oxygen propellants (about 15:25)
Final Inspection Team and Closeout Crew proceeds to launch pad
Resume countdown at T-3 hours (17:55 p.m.)
Perform open loop test with Eastern Range
Crew departs Operations and Checkout Building for the pad (18:00.)
Complete closeout preparations in the White Room
Check cockpit switch configurations
Begin Eastern Range final network open loop command checks
Flight crew begins entry into the orbiter (18:30)
Astronauts perform air-to-ground voice checks with Launch and Mission Control
Begin to close Discovery’s crew hatch (19:25)
Perform hatch seal and cabin leak checks
Complete White Room closeout
Closeout crew moves to fallback area
Primary ascent guidance data is transferred to the backup flight system
Enter 10-minute hold at T-20 minutes (20:35)
NASA test director conducts final launch team briefings
Resume countdown at T-20 minutes (20:45)
Transition the orbiter's onboard computers to launch configuration
Start fuel cell thermal conditioning
Close orbiter cabin vent valves
Transition backup flight system to launch configuration
Enter estimated 45-minute hold at T-9 minutes (20:56)
Final launch window determination
Launch director, Mission Management Team and NASA test director conduct final polls for "go/no go" to launch
Resume countdown at T-9 minutes (about 21:41)
Start automatic ground launch sequencer (T-9 minutes)
Retract orbiter crew access arm (T-7:30)
Start APU recorders (T-6:15)
Start auxiliary power units (T-5)
Terminate liquid oxygen replenish (T-4:55)
Start orbiter aerosurface profile test (T-3:55)
Start main engine gimbal profile test (T-3:30)
Pressurize liquid oxygen tank (T-2:55)
Begin retracting the gaseous oxygen vent arm (T-2:50)
Fuel cells to internal reactants (T-2:35)
Pressurize liquid hydrogen tank (T-1:57)
Deactivate bi-pod heaters (T-1:52)
Deactivate solid rocket booster joint heaters (T-0:50 seconds)
Orbiter transfers from ground to internal power (T-0:50 seconds)
Ground launch sequencer go for auto sequence start (T-0:31 seconds)
Booster gimbal profile (T-0:21 seconds)
Ignition of three space shuttle main engines (T-6.6 seconds)
Booster ignition and liftoff (T-0)
Preferred launch time: 21:50:27
And that, folks, is how the Russians do docking. One more 'green' for the shuttle launch then. :)
GUCP seems good - another 'green'.
Now to go crack hunting. :eek:
Finally a good launch window, been blooming ages since it was meant to launch.
Hopefully the girlfriend will let me sneak off for the launch haha.
It would be even cooler with a 'Danger, Will Robinson!' voice, That'd make a change from an alert tone when something goes wrong on ISS. :D
