Yeah, you would have a much better experience on a non-branded firmware. So you're on a 3 (H3G) 2.2 firmware? I'd suggest Samsung's JS5 if you can debrand it, it's a lot faster and lag-free, plus less bloat. I'm now on Darky's ROM 9.2 (based on JPY) and it's probably the best I've used so far. 9.3 will be out in not too long as well, which will be based on a newer firmware.
Don't check out this guide here, should have the phone running super-sweet if you do it.
Use this one now.
Just make sure you've read up on using Odin and checked the 3-button fix if yours doesn't work. I have a H3G handset and it didn't.
Use this one now.
