***Incredible WEEKEND ONLY UBER PAYDAY Deals!!***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I've got some stunning deals for you guys for PAYDAY WEEKEND, these prices will all increase Monday so get your wallets out this weekend and remember if you order by 2pm tomorrow (Saturday) you will get your parcel Monday. :)
Intel Core i7 970 3.20GHz (Gulftown) (Socket LGA1366) - Retail @ £431.99 inc VAT
Dominate your gaming competition with the six core Intel Core i7. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 970 is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.20GHz
- Multiplier: 25x
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- Includes Heatsink & Thermal Paste
Was [£459.99] Inc. VAT
Only £431.99 inc VAT.
ORDER NOW
Intel Core i7 990X 3.46GHz (Gulftown) Extreme Edition (Socket LGA1366) - Retail @ £799.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.46GHz
- Multiplier: 26x
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- 3yr Warranty.
Was [£859.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £86.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was [£99.99] Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £35.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible (use sub 1.60v)
Was [£41.99] Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £197.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Revision 1: Flashable to 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Card Dimension(mm) 275*110*38mm
- Warranty: 2 Years
Was [£219.99] Inc. VAT
Only £197.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 1024MB GDDR5 PCI-Express Graphics Card @ £204.98 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 835MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4050MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1670MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
Only £204.98 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 2048MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
Features:-
- Core Clock: 822MHz
- Memory Clock: 4008MHz (Effective)
- Shader Clock: 1644MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 460 GS 1024MB GDDR5 PCI-Express Graphics Card @ £129.98 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 700Mhz
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- Display Connectors: 2x Dual-Link DVI-I & 1xHDMI & 1 X Analogue
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was [£137.99] Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Intel X25-M Mainstream 80GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MH080G2K5) @ £142.99 inc VAT
Intel Solid-State Drives represent a revolutionary breakthrough that delivers a giant leap in storage performance. Intel Solid-State Drives are designed to satisfy the most demanding gamers, media creators, and technology enthusiasts. These new drives bring a high level of performance and reliability to notebook and desktop PC storage, at a fraction of the cost of the previous generation of Intel SSD products. Drawing from decades of memory engineering experience, and new, industry-leading compute-quality 34nm NAND flash memory manufacturing processes, Intel Mainstream SATA SSDs are designed to deliver outstanding performance, featuring the latest-generation native SATA interface with an advanced architecture employing 10 parallel NAND flash channels equipped with multi-level cell NAND flash memory. With powerful Native Command Queuing to enable up to 32 concurrent operations, Intel Mainstream SATA SSDs deliver higher input/output per second and throughput performance than other SSDs on the market today - and drastically out-perform traditional hard disk drives. These drives also feature low write amplification and a unique wear-leveling design for higher reliability, meaning Intel drives not only perform better - they last longer.
- Capacity: 80GB
- Controller: Intel
- Read: Up to 250MB/sec
- Write: Up to 70MB/sec
- NAND Flash: 34nm Multi-Level Cell (MLC)
- Interface: SATA-II
- Low Power Consumption
- Lightweight (80g)
- Shock Resistant
- Retail SKU Supplied with mounting brackets.
Was [£147.99] Inc. VAT
Only £142.99 inc VAT.
ORDER NOW
Samsung P2370 23" Widescreen LCD Monitor - Glossy Black @ £139.99 inc VAT
Ultra-slim and ultra-elegant, the Touch of Colour design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in. The ultra-slim 30mm depth not only creates more style in less space but also ensures exceptional all round efficiency. Up to 50% slimmer than traditional monitors, the modern, organic contours gently accentuate the elegance of your lifestyle and home.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 50000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x DVI-D (HDCP Compliant)
- Dimensions: 571.0mm x 423.0mm x 190.0mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was [£179.99] Inc. VAT
Only £139.99 inc VAT - SPECIAL PRE-ORDER PRICE ONLY!!
ORDER NOW
Truly unbeatable deals guys, get your wallets out! :D
Monday is the last day of the month. It is quite common as I used to be paid then. Now luckily for OCUK it's the 26th, which translates to today for this month.
DAMN YOU GIBBO!!!
The last friday of the month is quite common, some places I've been was every 4th friday and currently on the 1st friday - never have I been paid on a monday though.
Neither my wife or I get paid until Monday.
I know some places pay on the last Friday, but I think you will find that the last day of the month is more common.
last friday of the month is more common in my experience, every single job i've had has been that.
My gf does get paid on the last day though.
Wow... What a terrible fail. I for one get paid on Monday, just like a lot of others...
Stupidity in it's purest form.
Oh well, will just buy my 460 from a competitor on Monday lol.
Lost business there OCUK!
ags
ags
Are you for real? what a crappy attitude you've got.
Also your sig is too big.
