no mate,looks it.
I guess from that comment your going to need a psu upgrade? or some sort of cable adapter.
 will have to wait for 7990
But if I were a betting man, I'd say the GPUs' frequencies are lower than the Radeon HD 6970 - OK, I cheated and took a peek in the Catalyst Control Centre when Sapphire wasn't looking - so it may not quite be as fast as two HD 6970 GPUs in CrossFireX. What's more, should the CCC information prove to be correct, there may well be both 2GB and 4GB versions of the range-topping card.
It won't let me post the source. Wordfiltered.
Sounds like a google phone?
@Garee , but ccc doesn't show how many SP it has... if it has more it will be faster then 2 6970, even if it slightly under clocked.
I go on holiday on march 12th, so all money is being directed towards this![]()
A holiday can bring you enjoyment for a week before it's behind you, a 6990 will bring you happiness for at least another year.
 post from gibboWill one fan be enough cooling? :S
Why four display ports?![]()
no mate,
i have 2 8pins and 2 6pins...
i'm just surprise it's 2 8pins..
i was thinking it was 8pin + 6pin.
***BIT-TECH GOT THEIRS***
http://www.bit-tech.net/news/hardware/2011/02/28/amd-radeon-hd-6990-in-our-lab/1
Some better pictures of the card!!!
How come 6990 doesn't have HDMI port?![]()
As Gerard said, it'll come with a mini DP to HDMI adapter. My 5870 only has mini DP ports on the card itself, but came with DVI, HDMI and full size DP adapters.yeah i know thats gay !!!
