Hey there
The easiest way to do it is consolidate you itunes library on your pc.
Then copy everything from your itunes folder to an external hard drive.
Take all the files and drop them over the itunes icon in your macs dock & it will then put everything in the correct place.
That is assuming your itunes library is in the default folder on your pc, ie my documents/music/itunes.
That way you can have 2 backups of your itunes library one on the pc & one on your mac, the files for playlists etc are all the same hence the reason they can be copied over.
Also if you have any iphone/ipad apps on the pc these will get copied over as well.
Hope this helps
I picked up the high end 13 inch Macbook pro on tuesday night which replaced my 2009 Macbook, nice nippy notebook now.
Also use timemachine to backup your Mac to an external drive, it will back up all your itunes stuff that way.
Cheers
Hope this helps
Cheers
