starting to get a lot more into dubstep now, always been a bit curious with it (im mainly dnb personally and will likely stay that way)
i found listening to solo tracks quite a bad experience but a decent dubstep mix is something else....the UKF ones in particular seem to get it spot on.
I really dislike the direction that some artists have taken dubstep in. Especially ones that invoke comments such as 'LOL THIS IS SO DIRTY I SWITCHED TO PRON WHEN MY MUM COME IN MY ROOM ROLFMAO'.
I really dislike justin bieber and can't understand why he's so popular, which always makes me think that if you don't like the music don't listen to it.
soundcloud is not baaned as such, if the track involved is 100% original and not a mix of other peoples work and does not contain samples of other peoples work then it should be ok
you would also need to check any link on the page listed to check they conform to the above
if thel ink you posted meets the above requirements then repost it
