- 15 Jun 2007
- Liverpool
I can't get this to run at all? Click run and nothing happens.
Don't feel bad m8. You were no#1 for a while![]()
i'm not feeling badi'm surprised i was there so long
but i'm stuck with my 460 just now, the only card i can really upgrade to atm is the gainward phantom 560
Just under Krugga's 5850 which I'm not unhappy with at all, as the 5870m is somewhere between a 5750 and 5770, if I got the clocks closer to the 5770 it'd probably pass the barrier![]()
Mebbe split the dual core GPUs from the single core?
Here's mine
running at 820 gpu core and 4050mhz ram.
GTX580 performance for £195, bargain![]()
Here's my rerun
Just under MrKrugga's overclocked 5850 which I'm not unhappy with at all, as the 5870m is somewhere between a 5750 and 5770, if I got the clocks closer to the 5770 it'd probably pass the barrier
Get smashed by the higher end desktops, but what do you expect from a laptop (DTR)![]()
That's a impressive result for any laptop. But the 460s are a fair bit faster than the 5770s. I guess Heaven 2.5 is optimised better for ATI
It would be a good contribution to the thread if you had run at the correct settings. The resolution to run at is 1680x1050 with 4xaa. The reason for this is so we can compare all setups fairly and to include as much users as possible as not all people have resolutions at full hd and above.
All the information needed is in the op.
