A stock reference card is pritty good, but you can get a dual fan PowerColor HD6950.
Depends what you are used to ? personally I find those leaf blower coolers unbearably loud.
I'm abit baffled as mine is quiet, 24% fanspeed on desktop/windows, in games maybe upto 34% which is audible slightly above my case fans, but if you play with sound on or have headphones on you would never even notice it.
Same here. Sitting at 24% and the temps reported are 39ºC on the card. I find it's much quieter than my previous 4870 card with the stock cooler. Baffled how people find it loud.
Takes anything over 40% really for me to notice it. I've just bumped it up to 40% (I have music playing at a normal level, not too loud) and I still can't hear the fan. Anyway, back to 24% it goes.![]()
I bought the OcUK one and it came with the 2 fan cooler. It's pretty damn quiet.
The reference 6940 @ 24% idle is quiet, slightly audible when gaming.
How about this one? http://www.overclockers.co.uk/showproduct.php?prodid=GX-113-MS
Not sure if shaders can be unlocked on the MSI 6950 Twin FrozR II 2048MB, maybe someone else knows . . . .
Not sure then, only thing I can think of is splashing the cash on the ASUS HD 6970 DirectCU 2, although I cannot see anywhere with any in stock.
I doubt you can crossfire with the size of the cooler, also it will probally cost an arm and a leg too.![]()
They cantFirst one I looked at, read up on it a while ago and found out theres no bios switch. But yep, that would be ideal and probably worth the extra £30/£40. Ah well, can't always have it my way lol.
I'd just get the cheapest with a decent warranty ie not xfx or asus and put up with the noise until I could get an aftermarket cooler on there or pay the extra for a twin fanned jobby.
