A question about urine for biology boffins
Wow well I've learned a hell of a lot more today than I expected at the beginning. I have my two samples and will do some photos tomorrow evening when I get back from cycling.
Have we come to a consensus as to whether a sample of the sediment or a suspension should be taken for testing. I think perhaps both just to cover all bases.
Where can I get 95% alcohol from? Pharmacist?
There is no harm in doing both as neither way is really wrong, it just depends on which method produces easily visible results (and if you actually get 3ml of sediment, if not I suppose you can scale down your measurements accordingly).
Yes you can buy Isopropyl Alcohol from a pharmacy the last time I checked.
HARRIS!
...can you pee what it is yet?
/gets cloak
great thread gropingmantis, glad to see the spirit of enquiry exists on OcGD :D
edit: Gandhi for example drank a small glass (ie. first emission) of his own urine most days, and I don't think anything less of the man in fact I feel somewhat closer as a result of this thread ;)
Back at uni we had to collect peoples pee inside tubes and then do tests on it.
Is that disgusting too?
Well, no, I suppose that peeing in a bottle is 100000000000000 x more disgusting than that. :p
I'm more inclined to say that it's an inorganic product, such as salt, precipitating out of the urine. It could be similar to a saturated solution, where at body temperature when the urine comes out, all of it is dissolved in solution, but upon cooling, precipitates out into solution.
Might be a good idea to investigate this too, possibly by getting a fresh sample, and cooling it down from body temperature to room temperature and observing the physical changes.
Interesting thread is interesting; posting to subscribe. All the nay-sayers need to find their caves tbh. What's wrong with this type of inquisitiveness? Hell I've been doing weird stuff like this since I could walk. :D
I'd play along, but my kidneys are so wrecked (I'm waiting to have one removed :( ) that my urine's all kinds of weird. :p
i often pee in a bottle while im away working! sleeping in a camper for a good few weeks at a time its much easier waking up and doing that rather than getting dressed out into the cold walking across the site to find the toilet! ;) then empty it in the morning :D
Quick update before I go out riding.
No change in the samples. Last time it took about a day to begin to separate then another couple of days to fully settle.
Pics and method this evening.
OP should put his bottle of pee in direct sunlight for a few hours - if it goes purple he has acute intermittent porphoria. (Thanks JD and Turk!)
I dare OP to drink the pee after its been standing there a week
All in the name of science and experimentation
Is that will it overflow or not?
No. Get six bottles of Irn Bru, drink one and fill the empty with your liquid waste. Shuffle them up, tie a bandana around your head at arrange for you and a mate to be psycologically tortured by your nearest vietcong.
The OP is peeing in a bottle because he can't be bothered to go down some stairs. Also can't be bothered to wash his hands afterwards.
