well the setting is 1920x1080 @ 60hz in CCC and on the tv.. also switching from 3d to 2d the image quality is the same, as you would know if the res as gone lower as the quality of the image would be poorer.I assume thats rendering 2x960x1080 (or even 960x540) then which is why your not seeing as big fps drop.
and i'm using a 1.3v cable and it still works fine... the tv supports 1.4
from what i read side by side squashes the 2 images then the TV stretches them to the correct ratio to 1920x1080 resolution .The way side by side words is each 1080p frame has 2 images in it, one for the left and one for the right, side by side (hence the name) so this means you get half the horizontal rez (960x1080 per eye). For full resolution you need frame sequential, which has 1 frame for the left then 1 frame for the right, but as pointed out, this is currently limited to 24hz at 1080p in hdmi1.4. fine for movies, not so for gaming. If you cant tell the difference then that's great, you get the benefit of faster fps from the reduced rez.
http://www.iz3d.com/Hey Gareth, you are the man I neeed to ask!
I have the 40" version of that exact TV on the wall, and the wife has just bought the 46" that you got. I keep delaying swapping them because Im trying to find out if I can use the 40" for 3D, obviously I can now I know you do!
I looked into that IZ3d driver, but i cant seem to get the full version, where did you get it from?
Cheers in advance Gareth!
My 3D LED Monitor was £300... so 300quid jump from 24-27"?
mukhs11: My GTX480 runs metro2033 maxed with physx and dx11. So try it!
. 3 of those montors, all in eyefinity 3D.
one can dream right. 3 of those montors, all in eyefinity 3D.
(all powered by a singe GPU that uses one 6 pin pcie!)
maybe in 10 years.
edit, plus they need to be boarderless OLED.
