well have my beans and my grinder now and have had my first cup of freshly ground coffee. The caffine kick is emense you can feel it instantly. Was surprised at how much of a difference there was to grinding your own beans.
Excellent.
I am guessing the roasting process and the time the beans have been roasted also makes a difference and the packet from hasbeans tells me they were roasted yesterday.
The normal thing that i've seen about for life span of coffee is:
Green beans - 10 months
Roasted beans - 10 days
Ground coffee - 10 minutes
It's not entirely accurate as I've had some coffee 6 weeks past roast that have been magnificent, and some 3 days past roast that were dreadful.
Generally, the closer to the roast date the better.
So my first cup has been an interesting experiment I don't think I have managed to get the full flavour out of the beans yet so will keep experimenting. But I can certainly taste some of the flavours that steve described such as the honey and chocolate flavour but also seemed to be a hint of tobbaco flavour in there as well this seemed to be an after taste flavour rather while drinking.
Interesting, everyone will taste different things though.
What I find is that I have a notebook with all sorts of coffee listed in it, when I drank it, how I drank it, how old it was, brew peramaters and what the result was - it help me keep things organised in my mind.
Also for a french press how fine or coarse should i make the grind I am using a bodnum 8 cup press if that helps.
This is where coffee gets complicated...
I tend to use a reasonable coarse grind, much like grit, but it should be coarse enough not to go through the screen and fine enough not to take an age to brew.
And to that matter how many scoops should i be putting in. I only put in 2 heaped scoops on my first trial run but should I be putting in more?
One of the most important changes you can make now is use digital scales and a watch with a second hand or a countdown timer. The more things you can keep consistant the better, and the more you can play with a single element at a time.
Weigh the amount of coffee that goes in, weigh the amount of water too. Try starting around 60g coffee per 1000g of water. It's the normal starting point for me. I have used up to 80g/1000g at times though. I'm currently trying around 24g of coffee to 375g of water and a 4 minute 15 second brew time. I said it got complicated..
A lot of the info from Steve's Eva Solo brew guide can be used for the french press too.
http://www.hasblog.co.uk/brewing-guide-number-four-eva-solo
One of the changes I would do is once the water is added and has been stirred, add the plunger and press down slightly to push all the grounds into the water rather than having some float on the top. I actually find the french press the most difficult of the brewing methods to get consistantly right, yet it's the one you find most often in the shops.
But overall as my first experience into the world of home brewing I am loving everything about it. I am learning so much about coffee that I never realized.
Excellent.
