The time came
Cruise control is for fannys and Americans. The only cruise control needed by any man is his girthy right leg. Uggggggg!
FYI Chrysler sebring was lovely in California. Xxxxx
Some pictures after a quick session at the unit this evening/morning.
[TW]Fox;18637662 said:
AHAHAHAHAHAHHAAHAHAHAAHAHHAHAHAHAHAHAHAHAHAHAHA
You took the bait layed out especially for you :D:D:D:D:D
I'll do my USA write up when I can be bothered :p
Clio looks good Mike, finally!!!!!!!!!!!!
My 172 with a 182 style exhaust has much fatter pipes than the stock 182, which means to me the standard 182 ones look small. However, they also look centred correctly and don't rattle against the bumper like mine :)
Really, even at the back, they look different?
Heh, I wondered if someone would spot that :p The nsr is in fact a brand new budget put on by the dealer, presumably to address a puncture, as all the rest of the tyres have 5mm+. Replacement is on its way, however :)
And the lies creep in again, just goes to show even when he finally does something right he still manages to get it wrong.
How is one tyre even worth mentioning? it is far easier to say what I did than babble on about an odd tyre and why it's there. Stop looking for pointless reasons to derail what has been a perfectly sensible thread.
So new tyre + cambelt kit + pulley makes this car over 3k ;)
Nice car however, regardless of the milage.
How do you work that out? Aux, Cambelt and Pulley totals £380, tyre is £85 = 2715. Warranty company cover £300 of the cambelt and we're at 2415 :)
On a 182 with aircon you re looking at 480 at a specialist without the pulley! I would be shocked if the warrenty covers the cambelt, if it does then you re quids in :)
In which case why make a point of it having 4 amazing tyres in the first place, if you hadn't pointed (wrongly) then no-one would have brought it up would they? It's things like this that make everything you type subject to checking.
Sigh, I thought this thread was too good to be true. Sporting PE2's 'ALL ROUND' when oh actually it has a budget tyre. Why say it had them all round!
Why is a warranty company covering routine servicing? Not sure I understand on that one?
