It is normal on Macbook Pros, not so normal in the Windows world tbh. You get used to it after a while. I believe they are not allowed to advertise these as Laptops in the as they would be left open to being sued (Man puts "Lap"top on Lap and burns Lap/Legs...you can guess the rest!!). Part of the reason they get hotter (externally) is that it is made of aluminium which conducts the heat and acts like a big heatsink (I think!).One complaint with it - is I've found that it runs quite hot when I'm not even really doing anything. I've tried playing a game on it - And it wasn't graphically intensive - And it was burning my leg
I've never had a laptop before - so I can't compare and say if that's normal or not - but I think I'm going to download a temperature program to see what temps it is.
I'm never buying or building a Windows PC again. It's so intuitively easy to use, and basically (not meant offensively!) it's like working in Linux with a beautiful GUI that is actually easy to use.
On a separate note:
Quick question, I had a play with the new ones in the store the other day (just browsing, not interested in buying 1). What I noticed was that Activity Monitor only showed 1 CPU graph/bar etc. My Core2Duo model shows 2 (as did the Airs on display). How come the i series don't show this on OS X (I am fairly sure they do on windows). Just curious really, seemed a bit strange to me.
rp2000
Got my 13" today, and all I can say is 'WOW!'.I'm never buying or building a Windows PC again. It's so intuitively easy to use, and basically (not meant offensively!) it's like working in Linux with a beautiful GUI that is actually easy to use.
I'm hooked.
BTW, mine runs lovely and cool (so far) but I read that the thermal paste is hit and miss on MBPs and many people re-do the TP which is an instant cure for running hot. YMMV.
I've checked Activity Monitor and mine's showing 4 cores (Core i5 cpu).
Must have had it for about five years... wonder if it's still good to use
It was bad enough putting in the RAM hands shaking all over the place
On a separate note:
rp2000
I've fixed lots of computers in the past, even built a few completely from scratch.... so why am I absolutely terrified to even contemplate opening my new mbp up to apply thermal pasteIt was bad enough putting in the RAM hands shaking all over the place
I've seen a few people talking about that around the web. Mine definitely shows all four cores though (2x physical, 2x logical) on my 13" core i5. Maybe it's a user-configurable option?
http://www.rainmakerkennels.co.uk/images/osx-2011-corei5-cores.png[img][/QUOTE]
Hmm... Mine looks different...
[img]http://i53.tinypic.com/bhwq6u.png
Tomorrow I'll try playing a game for a while and see the temperature - It was red hotThose temps look about right, here's mine:
Looking around the internet the problem MBP's have had temps up to 100 c!
Tomorrow I'll try playing a game for a while and see the temperature - It was red hot![]()
Notebook Journal also finding its machine throttled down to 798MHz due to heat dissipation issues. PC Pro theorizes that Apple intentionally disabled the Turbo Boost functionality on this particular MBP model in order to preserve your lap and your pride from being scalded by melting components. That would make sense to us, and hey, it's still a fast machine, just not Turbo fast.
