Not checked this thread for a while but looks like you've come on a long way, and it'll be a pretty sick case when it's finished.
Thanks SouthEastBlue got a good update here
Now that's what I call British Engineering.
Thanks exotic444 & I'm not an engineer, just a custom pc case enthusiast
, make britain great rather than run away from it hehe
Started 6 am Friday, finished 8 pm had a few quick coffee breaks.
Days like today make me remember why I make my own cases, the past few days I've been questioning why am I bothering doing this lol & the answer is in the pictures, the first botch up panel was one of those where I don't know what to make of it & wondered if I could grow to like it but todays effort I knew immediately I'm glad to say wooooooo
OK so I missed out on taking pictures with the custom circle hex pattern I downloaded, printed from
http://incompetech.com/graphpaper/ but I cut to size & stuck down with cello tape & marked the centre of each circle which tested my patience over a few sessions through the night lol but whenever it got too much I just watched a show to break the monotony & when it was done I covered it in cello tape so it all stays down & left until 6 am.
Not sure how long the spot drilling took but it was quite a while, then drilled a 3.2mm bit & then used a 7mm bit, then got my bigger countersink bit & accidentally went too deep on the first one so did all the rest at the same depth & pretty fast I noticed it was a good accident for 2 reasons: 1 it adds a nice & easier way for the air to get through, 2 I think it looks pretty damn good.
The circle at the bottom I wasn't sure if I should go with a plain hole or do the mesh so I went with the mesh & had to just use a few 3.2mm holes for the ones closest to the edge of the wanted circle, not a bad result I think
Flipped the piece over & done slight countersinks on the exterior side, then used wd40 to get the tacky cello tape completely off & then used the satinising mop to minimise scratches & then went over it with a fine satinising mop, dusted down & installed back to the case & wow I love it when I impress myself & feels a fair while since I done that, so then enough blah blah & enjoy the pics
Awesome day
