Caporegime
- 18 Oct 2002
I really don't think this will be the case at all. The RPV is well shielded and it is unlikely there will be anyone in that close a proximity anyway. The diesels themselves are away from the Reactor in a separate building. This is done in the case of an aircraft impact so that all the key services aren't located in the same building, it spreads/disperses the risk.
Yet we know that venting gas had radiation exposure, ceasium has supposedly been detected and the problem isn't necessarily with the generator, if they can't get the generator cooled to slow down any issues they might have to find alternative ways to cool the reactor and being in and around the site with the reactor, which may or may not be partially damaged(which the suggestion of Ceasium detection suggests is more than possible) then its a simply dangerous area to be in.
Yes if the problem is ONLY with the generators and theres no leaks or pressure venting in the second building, and they don't have to go anywhere near the main reactor the risk is reduced but not 100% safe by any means, as suggested by supposedly 3 people being exposed already.
