On your average turbo, how long after a spirited run should you leave the car to cool down before turning the engine off?
I always sit there for 2 minutes then consider that enough but tonight a guy happened to be outside his house, and when I got out he asked why I'd been sat with the car running. I explained and he said 2 minutes is no where near enough.
Also, say you turn your engine off straight away, as I understand it, the issue with this is oil still in the turbo dries and clogs up, does this mean when you next drive with a heavy foot, does this clogged oil get removed when everything gets hot again?
Cheers
Cheers
