I've read a few grim things about EBC, enough to keep me from buying them.
EBC Blue are superb pads, well worth buying.![]()
But as Dup points out, they don't seem to make too much sense for fast road cars going by the press reading.
I've got yellows to go on the back. I think I'll be going for Carbotech on the front (£200 a set though)
The K-Sport kit I am interested either comes with either
the original K-Sport pads (+£0)
EBC Bluestuff (+£99)
Ferodo DS2500 (+£181)
Now I've heard the K-Sport pads are pretty crap, and have been told the Bluestuff are good for both fast road and track (ScoobyDoo69 and McHaMmEr seem to confirm this).
Now seeing they are half the price of DS2500s, is there a good reason not to go for them?
People have rated these pads better than the DS2500s on scoobynet...
Yep that's the one. Decided on the K-Sport over the Wilwood 330mm in the end..Definitely go for the Bluestuff pads if you're going to buy the k-sport kit, £99 is a decent price and they are far superior to the k-sport pads. Are you buying the 8 pot 330mm kit?
Sounds just what I'm afterThe EBC bluestuff is deinetely better than DS2500.
Guys on the EVO forum have had very good results, on the X as well, its a superb road pad and seems to compete well against the carbotech XP8/XP10 but gives of less dust.
