 - 27 Jan 2003
 - Chesterfield, UK
Hardware: I7 920 DO [email protected], XSPC RS360 Rad+Vipers, EK Supreme HF CU, EK 5870 FC Block, D4 Vario on Min, 1/22 pipe, 800D.
All tests with full fans also made sure temps started around 30-33'c
LinX Load Testing 15K Problem size, 20 runs ( 18 Mins )
Tested 4 TIMS Noctua NT H1, MX4, Perihelion, IC24
Noctua NT H1 - FAIL
LinX produced GFLOP ranges from 35 - 48. This I believe was caused by Thermal Throttling. Everything appeared to be OK after removing the block and I had been using the system for about 4 months.
Perihelion
Peak Load - After 24 Hours
67,66,64,63
Peak Load - After 48 Hours
70,69,67,67
Strange, temps seem to get worse. After removing the block the top of the chip wasn't covered but still more than 80% covered. This was the first time I used the Pea method so I suspect insufficient compound.
MX4
63,59,61,54
62,58,59,53
Really like MX4, very easy to spread. Good even spread after removing the block.
IC24
62,58,60,54
61,57,59,53
In my system IC24 performs very similar to MX4 with IC24 having a slight edge.
Noctua NT H1 - FAIL
Perihelion
67,66,64,63
70,69,67,67
MX4
63,59,61,54
62,58,59,53
IC24
62,58,60,54
61,57,59,53
