My idea is that light can only travel at one speed as it has no resistance, so therefore it would take 600 years for the first bit of light made in the process of the star dying to get to our eyes?
It's more than just 'no resistance', its that light travels at the same speed
regardless of your inertial motion, unlike other objects.
Suppose you have a gun and suppose you also have a target which can measure the speed of bullets which it it. You stand still and point the gun and fire and the target gives a read out of 1000kph. Suppose you get in your car and drive towards the target at 100mph and fire again. The target will read out 1100kph.
But what if you do this with a laser? Stand still and fire your laser at the target and it'll read 300,000 km/s. Now you get in your car, which happens to have a top speed of 100,000 km/s, get to top speed and fire your laser. What does the target say? It'll say 300,000 km/s! Doesn't matter if you're driving at the target, away from it, around it in a circle, it'll be 300,000 km/s.
That is what it means to say "The speed of light in a vacuum
is 300,000km/s". In the case of planets or rocks or bullets the speed you measure is dependent upon your motion. If you drive a car at 40 mph (which is measured relative to the ground) you'll overtake someone driving at 10mph at a relative speed of 30mph. However, if you both turn on your headlights then someone further down the road will measure the speed of the light particles coming from each of you to be precisely the same. Hence why the speed of light in a vacuum is well defined without reference to anything else, it is
independent of the motion of the emitter and the detector (up to subtle things to do with non-inertial motion).
While light's speed and direction can be affected by specific mediums such as Glass, and forces such a mavity (the Variable Speed of Light)
To what are you referring?
