Electricty generation / MPG
15 Feb 2003
Europe
Sorry, maybe a daft question, but can anyone tell me why people say that using more electronic devices in the car uses more fuel?
Isn't electricity generated by generated by the movement of a loop of copper wire, between the poles of a magnet?
The speed of the spinning is dictated by the speed of the engine.
With this in mind, how does it make a difference how many electronic devices the car uses?
Because you're putting more electrical load on the alternator, so the engine has to do more work, even if it's running at a constant speed.
If you put loads of electric devices on in a car you can sometimes hear the engine sound change as the alternator pulls more load to the battery and causes a few extra rpms. You can hear it at idle more clearly than at speed though.
Its the same concept of the AC drawing power away from the engine.
You would have to be using a lot of gadgets though to make as much as a difference s the AC!
I can feel the drop in power turning the AC on on the motorway, speed drops about 2mph from 70 when keeping my foot still on the accelerator!
Conservation of energy innit, the generation of energy by the alternator means the axel is slowed so you have to increase engine output for a given speed.
Sightly different the AC is driven directly by the engine so it's obvious this uses energy, I think the op isn't aware that the generation of energy by the alternator uses energy, despite there being no contact between the wire and the magnet producing the magnetic field.
Sightly different the AC is driven directly by the engine so it's obvious this uses energy, the op isn't aware that the generation of energy by the alternator uses energy, despite there being no contact between the wire in the magnetic field.
All driven by the same belt are they not?
It still doesn't make any sense to me. Surely the altenator just spins around some magnets or spins a around a coil. And it spins as the engine is spinning.
This is my understanding of electricity generation. http://www.youtube.com/watch?v=MBMYdE5NQOQ
So imagining that the wand he has in that video moves up and down as the engine spins, then how does it make any difference as to how many devices are plugged in? The wand would always move at the same speed for a given RPM. e.g 100 movements at 1000rpm, 500 movements at 5,000 rpm.
Edit: ok so the alternator rotates a magnet that doesn't touch anything. how is there a slowing force on the engine when it magnet doens't touch anything, so no friction. Surely the pull from the magnet never changes.
When no current is being produced in the around the alternator (ie everything off) the magnet is free spinning and no electricity is produced.
When a current is being produced the rotating magnet induces an electromotive force in the stationary wire (it pushes the electrons, creating the current), so experiences a decelerative force. Kinetic energy is converted into electricity.
The decelerative force is not due to friction, it is due to the having to push a wire through the magnetic field effectively and creating the electromotive force (although in the alternator its the magnet that is pushed relative to the wire).
Your assumption that there is no slowing force is incorrect. Just because there's no friction doesn't mean there aren't any forces acting which slow it down.
Isn't this covered in GCSE physics any more?
The alternator has magnets spinning in a coil.
The magnets have a magnetic field like this:
Even though the magnet is spinning not the wire, we can imagine it is the other way round.
For the wire to cut through the magnetic field lines (and hence create moving electrons and electricity) it takes energy, so that's why it creates a load on the engine.
Imagine trying to force two magnets (N and N or S and S) together, or pull S and N apart, it takes work.
Similar principle.
Fair enough. spinning the magnet in the demo generate at school was pretty easy and I didn't feel any resistance no matter how many light bulbs were attached. But I understand the theory. Cheers.
It's kinda like if you had a power station which basically have massive alternator/generator you couldn't run it from your 1.6 petrol engine and it aint just to do with friction.
You can't make or destory energy, only change it's state. GCSE science ***.
Not for a few years afaik. We only covered eddy currents at A level, and that was a few years ago now. Some kids today don't even do a GCSE physics course. :eek:
