http://www.ustream.tv/channel/geiger-counter-tokyo
The joys of the interwebs, although there is no way of knowing if this is actually in Tokyo
What's a 'normal' level?
if the core is intact, how can heavy metals be released? the gas that is being released is the cooling liquid
As someone said on the radio yesterday, trying to evaluate the effect on the Japanese economy is like trying to evaluate how tangled is a bath full of spaghetti.
A company that manufactures widgets in an untouched part of Japan may still be effectively put out of business by the tsunami for many reasons. Their main customer may have been wiped out by the tsunami or a group of clients that owe them substantial sums of money for goods supplied may have been wiped out or their raw materials or exports may all go through the port of Sendai.
It will take three to six months to even begin to get a reasonable picture of the likely impact.
Not really, disaster often sparks economic growth after a downturn.
The Kobe earthquake caused a downturn in the economy for half the year after, and the half year after that was better than had been predicted before the earthquake, why, rebuilding. As horrible as it is, SO much work needs doing now that didn't need doing before, more jobs, more work, more wages, less unemployment, etc, etc.
Different world market and economy compared to then though and, they've sunk money into building nuclear power plants that, well, I wouldn't be surprised if those plans are scrapped, considering they were building two more alongside the failing reactors. Energy could be the reason Japan has huge economic problems in the future.
Counts per minute (cpm) is a measure of radioactivity. It is the number of atoms in a given quantity of radioactive material that are detected to have decayed in one minute. Disintegrations per minute (dpm) is also a measure of radioactivity. It is the number of atoms in a given quantity of radioactive material that decay in one minute. Dpm is similar to cpm, however the efficiency of the radiation detector (e.g. scintillation counter) must be accounted for when analysing data in cpm. Dpm is the number of atoms that have decayed, not the number of atoms that have been measured as decayed. Dpm is commonly used as a measure of radioactive contamination.
* One becquerel (Bq) is equal to one disintegration per second, or 60 dpm.
* One curie (Ci) is equal to 3.7 x 10 10 Bq or dps, which is equal to 2.22 x 1012 dpm.
So what does that mean ? bad on human health ? 12.98
Now thats what I call organised..... Who recalls what what the lines looked like in Haiti?
The real question is why does it look like they put tracing paper over the Thames...
Crisis continues at Fukushima nuclear plant as fuel rods exposed again
TOKYO, March 15, Kyodo
A crisis continued Tuesday at the troubled No. 2 reactor at the quake-hit Fukushima No. 1 nuclear power plant, as fuel rods became fully exposed again after workers recovered water levels to cover half of them in a bid to prevent overheating.
The plant operator, Tokyo Electric Power Co., said a steam vent of the pressure container of the reactor that houses the rods was closed for some reason, raising fears that its core will melt at a faster pace. It said it will try to open the vent to resume the operation to inject seawater to cool down the reactor.
Despite its earlier attempt to do so, however, water levels sharply fell and the fuel rods were fully exposed for about 140 minutes in the evening as a fire pump to pour cooling seawater into the reactor ran out of fuel and it took time for workers to release steam from the reactor to lower its pressure, the government's nuclear safety agency said.
Water levels in the No. 2 reactor later went up to cover more than half of the rods that measure about 4 meters at one point. TEPCO began pouring coolant water into the reactor after the cooling functions failed earlier in the day.
Prior to the second full exposure of the rods around 11 p.m., radiation was detected at 9:37 p.m. at a level twice the maximum seen so far -- 3,130 micro sievert per hour, according to TEPCO.
To ease concerns, Chief Cabinet Secretary Yukio Edano said he believes the problem at the plant ''will not develop into a situation similar to the (1986 accident at the atomic power reactor in) Chernobyl'' in the Soviet Union, even in the worst case.
Officials of the Nuclear and Industrial Safety Agency also said the worst case scenario will be less destructive than the Chernobyl incident, as TEPCO has depressurized the reactors by releasing radioactive steam.
The utility said a hydrogen explosion at the nearby No. 3 reactor that occurred Monday morning may have caused a glitch in the cooling system of the No. 2 reactor.
Similar cooling down efforts have been made at the plant's No. 1 and No. 3 reactors and explosions occurred at both reactors in the process, blowing away the roofs and walls of the buildings that house the reactors.
Edano denied the possibility that the No. 2 reactor will follow the same path, as the blast at the No. 3 reactor opened a hole in the wall of the building that houses the No. 2 reactor. Hydrogen will be released from the hole, he said.
The blast earlier in the day injured 11 people but the reactor's containment vessel was not damaged, with the government dismissing the possibility of a large amount of radioactive material being dispersed, as radiation levels did not jump after the explosion.
TEPCO said seven workers at the site and four members of the Self-Defense Forces were injured.
Since the magnitude 9.0 quake hit northeastern Japan last Friday, some reactors at the Fukushima No. 1 plant have lost their cooling functions, leading to brief rises in radiation levels.
As a result, the cores of the No. 1 and No. 3 reactors have partially melted.
The government ordered residents within a 20-kilometer radius of the plant to evacuate Saturday in the wake of the initial blast at the plant's No. 1 reactor. A total of 354 people are still attempting to leave the area, according to the nuclear agency.
The agency ruled out the possibility of broadening the area subject to the evacuation order for now.
==Kyodo
U.N. nuclear watchdog to send team of experts to Japan
VIENNA, March 14, Kyodo
The head of the International Atomic Energy Agency said Monday Japan has asked the U.N. nuclear watchdog to provide experts in the wake of a series of incidents at a major nuclear power plant hit by Friday's massive earthquake in Japan.
IAEA Director General Yukiya Amano said the IAEA is in discussions with Japan on the details, according to a statement released by the agency.
He was informing member states about the request in a technical briefing about nuclear safety aspects of the situation in Japan.
==Kyodo
It sounds as if there has been leaks of radiation and seems plausible that some people have higher radiation levels then normal so I'm wondering if its plausible that the government of japan and the energy companies might try create a cover up in order to keep peoples trust in nuclear power.
I can see 10 years from now a lot of people being sick because of this incident.
I'm not talking about conspiracy theories, but just seems like something that happens in this world? Do you think this is possible?
What like lots of people being really really sick 10 years later because of chernobyl?It sounds as if there has been leaks of radiation and seems plausible that some people have higher radiation levels then normal so I'm wondering if its plausible that the government of japan and the energy companies might try create a cover up in order to keep peoples trust in nuclear power.
