The DG has it and at £21 for the OEM its an absolute steal!
USB or PCI-e? The Emu 0404 USB has both optical in and out but is a little over budget...![]()
Not many seem to have the optical out connection on the back. Will keep looking
Thanks
Do you have a link to that card Andrew
USB or PCI Mike, not really fussed as long as it works well. 5.1 will do although 7.1 would be a bonus.
They do. Most use mini toslink, and come with an adaptor to connect a regular toslink type. Mini toslink is basically a 3.5mm jack shape. The sockets look like any other 3.5mm socket, which fools a lot of people into thinking the card in particular doesn't have optical out.
Would be useful for those who don't know this, if the description stated that the card has optical out capability.
http://www.overclockers.co.uk/showproduct.php?prodid=SC-012-AS for OEM at £19.99 until wednesday where it becomes £20.99
http://www.overclockers.co.uk/showproduct.php?prodid=SC-011-AS&groupid=701&catid=11&subcat= £26.99 for retail which includes the box as the added extra.
. Before and up to around the time when the X-Fi was released, Creative cards required a separate device. Either a 5.25" live drive, external box, such as which came with the X-Fi Elite, or a module which had SPDIF connections.
Err. Not quite. I have an X-fi with an optical out and an optical in. Its an SB0770 and is an OEM as used by Dell and HP amongst others.
