Fractal Design Price Drops!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys the Fractal Design XL cases are now down to the same price as the small R3 sized case.
Fractal Design Define XL Full Tower Case - Black Pearl @ £84.98 inc VAT
As the name implies, Define XL is the larger sibling of the acclaimed and award winning Define R2/R3 case. Similar to Define R2/R3, it offers a number of interesting functions with a very stylish appearance. It’s a case focused on low noise level, without neglecting other important features such as cooling, expandability and ease of use.
The XL is pre-fitted with dense noise absorbing bitumen material, covered with a soft foam texture. This material effectively absorbs noise generated by the components and fans inside. Paired with other noise preventing features such as a covered top panel with a 180mm fan mounted with an angle to blow out air in the rear and silicone grommets for hard drive mounting, the XL truly excels in delivering a low noise solution.
An important feature of the XL is the division into three thermal chamber designs. This enables the user to freely choose the best thermal configuration suited for their needs. First is the upper main chamber, containing most of the components, such as motherboard, ODD and one HDD cage. The main chamber is cooled by one 140mm fan in the front (included), one 120mm fan in the front (optional), one 140mm fan in the rear (included), one 120 or 140mm fan in the side panel (optional) and one 180mm fan in the top (included). The top 180mm fan is mounted with an angle, blowing out hot air through the rear side of the case. As mentioned earlier in the text, having the top covered has a clear acoustic advantage, in not letting noise emit from the top of the case. The main chamber is connected to the second thermal chamber, the PSU chamber, with a removable lid. The lid can be removed if the user wants to turn the PSU upside down, pulling out air from the main chamber. Standard, and recommended, configuration is though with the lid closed, letting the PSU taking in air from the bottom of the case, through the supplied filter.
The third chamber is the lower HDD chamber, consisting of room for six hard drives. This chamber is cooled by an optional 140mm fan in the front. The standard configuration is to let the air that has gone through the HDD’s and therefore is hot, go out behind the right side panel (seen from the front) and out in the rear of the case. However, the user can decide to remove the dividing metal panel between the lower HDD chamber and the PSU chamber, to let the air flow over the PSU and out in the rear ventilation holes.
Another unique feature with the XL is the ModuVent™ feature, inherited from the Define R2/R3 case. This is a cover fitted with noise absorbing material, mounted in the side panel fan hole, allowing the user to choose between an optimal low noise level, having the cover mounted or optimal airflow by removing the cover and mounting a fan for intake.
Apart from all these features, XL also offers excellent cable routing possibilities, with large holes and well enough space for cables behind the M/B plate. The cable routing holes are covered with silicone covers, effectively hiding the cable clutter.
A fan controller, which can be mounted in an expansion slot in the rear, is included. It can control up to three fans with one knob.
- 4x 5,25” bays, 1x 5,25” to 3,5” converter included
- mini-itx, micro ATX, ATX and E-ATX motherboards
- 10x HDD trays. 4x HDD trays in the HDD cage in the main chamber. This HDD cage is removable and rotatable. 6x HDD trays in the lower HDD chamber. These HDD cages are fixed.
- A total of two 140mm fans and one 180mm fan included. Front 140mm fans are mounted with removable, washable filter. A fan controller is included, for mounting in one of the rear expansion slots.
- Pre-fitted with dense noise absorbing material in both side panels.
- ModuVent™ feature, allowing the user to choose between an optimal low noise level, having the cover mounted or optimal airflow by removing the cover and mounting a fan for intake.
- 2x 140mm fans (one 140mm included, one optional) with removable and washable filters, in the front. Recommended for intake of air.
- 1x 120mm fan optional with removable and washable filter, in the front. Recommended for intake of air.
- 1x 180mm fan included in the top of the case. Recommended for exhaust of air
- 1x 140mm fan included in the rear of the case. Recommended for exhaust of air
- 1x 120/140mm fan optional in the side of the case. Recommended for intake of air
- Case size (WxHxD): 232 x 560 x 561.3mm
Only £84.98 inc VAT.
ORDER NOW
Fractal Design Define XL Full Tower Case - Titanium Grey @ £84.98 inc VAT
- Mini-itx, Micro ATX, ATX and E-ATX motherboards
ORDER NOW
Is there meant to be 2 Design XL's in the OP? What about the regular?
Darn it, I was looking at getting this and the new price is tempting but I've not long got a H70 and it takes a 120mm fan, not the 140mm on this case, DOH! :(
It does. I emailed Fractal about that a while ago.
Been thinking of getting one of these for ages. How long is this price going to last? Need to go scrape together my pennies.
Lol was just about to secure one of the XL's along with £230 worth of other bits I didn't need but was put off by the negative comments on cooling in the case
Shame as I really like it
It's the cooling of my gfx cards I'm worried obout the most
CPU not so much as a d14 was on the list too
Also
Fan controllers with round dials ive read, have to be set back on the front of the case in order for the door to close !:eek:
Also
It comes with a fan controller :confused:
also you can place a fan on the side panel which would be blowing directly onto the GPU
Also
From the Bit-Tech review:
Conversely, GPU cooling proved to be excellent in the XL, largely because the graphics card is perfectly placed to eat all the cool air provided by the front 140mm fan. The maximum delta T of 39oC was among the best we’ve seen and 3oC cooler than that achieved by the R3.
I know it comes with a fan controller but if you accommodate the rest of the fan spaces I'm going to need some sort of fan controller
Got mine today. Titanium Grey. God is it quiet. Wanted a Cosair 600 T because of my H70. Saw a Vid on youtube with the H70 fitted. So ordered this instead. Very pleased.
Changed my H70 to push/pull instead of exhaust now my temps have gone from the low 30's to 35-40!! will change tomorrow and post back.
ATI Sapphire ATI Radeon HD 5850 Toxic 2048MB @950 & 4800
i5 2500K
Asus P8P67 DELUXE Intel P67
Corsair Vengeance 8GB (2x4GB)
Creative Sound Blaster X-Fi Titanium 7.1
Windows 7 Ultimate 64bit
MS Swidwiner X6 gaming keyboard
MS Swidwiner X5 Mouse
Dell 2408 WFP 24"
4.7 TB HDD Space
Super Multi Blu-ray, HD DVD
