2xHD6850
22 Mar 2009
Cornwall
hi, thinking of getting another HD6850 at the end of the month, but a few quick questions first :
1. what single card(s) will it be equivilant to
2. has anyone experienced any issues with these in CrossFire
Definitely worth it for a medium-long term solution (as you'll have to replace both to upgrade). It won't be as fast as a 580 or a 69xx on DX11 + tessellation heavy games like Metro, but they'll still be completely playable at medium settings on 1920x1200 or lower.
I think a closer comparison would be the 5970, where 6850cfx is pretty much neck and neck across most benchmarks.
ok kool. dont really want to sell my HD6850 and then buy a single card with the money as my card is only a month old, so thought getting a second would be the best bet. just wondered if it would make a great deal of difference, and if people had issues with it, or crossfire in general in most games.
Not with the 6xxx series. CFX scaling is excellent compared to 5xxx - consensus amongst many (not all! lol) is that it's slightly better than nvidias for this generation.
As much as i tried i could not get a pair of 6850's to work, im sure it can be done but just google 6850 crossfire bsod and you will see what im on about
Heard that there was a bad batch of cards causing lots of bsods at one point - is yours a card problem or a driver issue?
hmm.............mine is a gigabyte card, and the second one will be too. not sure if it makes a difference though. maybe its the mobo causing the BSODs not the cards? i know i have 3 16x PCI-E slots so i should be ok speed wise :)
It'll be about as fast as a 580gtx, win some, lose some. Not a lot in it.
http://www.techpowerup.com/reviews/ATI/Radeon_HD_6850_CrossFire/8.html
Direct comparison is difficult as few people have done it however here, 6850 xfire beats a 5970 by a 5% or so.
http://www.techpowerup.com/reviews/ASUS/Radeon_HD_6990/11.html
Here you see a 5970 beats a 580gtx by, well its a hair under 30% faster and the 6850 is marginally faster than that.
Close, not remotely, basically a 5970 is roughly speaking, averages maybe 20-25% faster than a 5970, the 6850 is marginally faster. 6850 xfire IS, just without question faster than a 580gtx, some games it will be slower, but not many.
Unfortunately reviews are a pain to navigate, I used techpowerup for some individual benches, don't read the performance round up at the end, I don't know how he does maths, but it isn't correctly. Look though any old review, and then tell me if the 5970 is 5% faster than the 480gtx that their latest performance round ups suggest, at launch of the 480gtx, they said it was 40-45% faster on average, thats gone down monthly, as they take out gpu limited games, add CPU limited or Nvidia ones and turn off xfire in things like Call Of Juarez, its an "amd" game, its 70% fasrer than the 480gtx at launch, since they turned off xfire its now marginally slower, xfire works in Call of Juarez :(
Its just the easiest site to find reviews with wide ranging comparisons to be honest, his conclusions/round up couldn't be more paid for these days.
6850's are insanely good cards for the cost, they also overclock pretty damn well so will fair a lot better than a 5970 when overclocked, scaling is ridiculously good in so many games now. The only time I wouldn't recommend SLi/xfire on latest gen cards is if you have a mobo/case/spacing that means the cards will be alongside each other as the top card will run stupid hot and stupid loud. If you can fit them in say slot 1 and 3, it won't be an issue, go for it.
Blimey...is it just me or are all the commas in that (very informative piece!) scattered randomly around the paragraph like pigeon feed :p:)?
Yup, I'm sure it will vary from bench to bench. I only looked at the one for a quick comparison. :)
sooo tempted to just hit the 'buy' button, but have to wait til monday.......wife would kill me else.
Just curious, what is the performance like with one card? I'm trying to get a 'real world' idea before looking at my next purchase. I may go for low power draw with adequately high performance; or I may go for something very different. Depends on circumstances.
so far i havent found anything it wont run mid/high settings @ 1920x1080 playable. but i dont play a lot of first person shooters, so the FPS probably isnt as noticable in things like fifa, f1 2010 and NFS:Hot Pursuit. i think, compaired to my 2xHD5770s i had last year it is a lovelly card, but at the moment i have a servere case of the upgrade itch, so i want more :) got my case and cooler delivered yesturday (£80) and have only recently got my mobo/cpu/gfx card as i was without a pc since last summer as i thought the PS3 would do me, but alas, it didnt, the urge for a pc took over.
