the door is flimsy and totally pointless - you dont need a door on a computer case.
plastic on any case looks cheap unless pulled off well. nzxt cases are particularly nasty and arguably the worst offenders for this crime.
the hard drive holders bend in half easily and certainly dont insprire confidence in transport.
i wouldnt want to entrust my data in them
the paintjob is the typical nzxt cheapo powedercoat. put it next to a silverstone fortress ft01 or even the panels on an antec 902 and tell me its not bad.
the panels are poor. there really is no argument there, every nzxt case is the same.
the watercooling radiators are supposed to be held on by some sort of silly arm system [these metal brackets which fold easily] with three screws supposed to hold a 240 rad in place. i somehow dont think so.
i wouldnt personally hold a heavy/full 240 radiator over my expensive hardware with these.
it
is overpriced.
i would take a coolermaster sniper/dominator or lian li pc50/pcb25 over this case any day of the week
it does nothing better than the dominator which is better built and has a superior layout.
sorry, i understand that you like your case. but i build a lot of computers, and this case is not something i would suggest as an option to anyone.
