Friday thought......random as hell!
30 Sep 2006
Midlands, UK
Was just wondering:
if diamond can only be cut by diamond (or so i've always been led to believe), imagine having a small engagement ring sized full quality diamond placed on an anvil, and it being struck by a huge well'ard hammer.
You telling me it wouldn't break the diamond?
I find it hard to believe that it wouldn't.
Discuss........
.....if yer like! ;)
Delicious copy pasta:
While diamond is the hardest naturally-occurring mineral known, it is also brittle. The hardness means that it is difficult to cut, but the brittleness means that it is likely to splinter or shatter if enough pressure is exerted. In the case of a diamond hit with a hammer, the likelihood that the diamond will shatter will increase with the force of the hammer (based mostly on the weight) and will further increase if the diamond has any significant inclusions (indicated by a flaw in the diamond).
Read more: http://wiki.answers.com/Q/Will_a_diamond_shatter_if_hit_with_a_hammer#ixzz1Gwrwvwnx
End of discussion? *trollface* :p
I think cut and break is different for this.
I believe by cut, they mean nice flat finish. I have no doubt that you could break the diamond by the method above.
