Limescale removal from kettle element
1 Dec 2006
Amsterdam, NL
Well, we were ignorant to the fact we have 'hard' water when we recently moved into our new house and we didn't bother picking up any filters for our brita water filter.
Now we are left with a near ruined kettle...
Any ideas on how to get the limescale off easily?
Thanks, ags.
Look for a product called Oust in Wilkinsons.
It's a pouch of liquid you add to boiling water and fizzes away getting rid of the limescale.
Does that sort of thing work in coffee machines? I left mine standing for a month and loads of muck has settle on the heating element.
The box gives instructions for kettles, coffee makers, steam irons and showerheads.
Best of all it's cheap and works.
This, works very well.
Also you can get something that 'absorbs' the limescale, it's like a small wire-wool type thing. My parents have one in the kettle and just needs cleaning every now and then, works very well.
I use water mixed with malt vinegar (about 50/50), and just make sure I stop it before it boils over, and then quick scrub with the kitchen brush to finish it off.
Usually leaves it sparkling and bright :D Tea always tastes so much better afterwards.
I descaled our kettle recently. It then started leaking. Turns out the limescale was blocking up a couple of small holes in the edge of the window that shows how much water is in it.
Oops.
I'm glad we dont have this limescale issue in Scotland.
Hooray for our soft water!
I thought it would be worse in Scotland. Not for any real reason though.
At work we can't use tap water because of all the lead pipes (fun). So we use bottled spring water (very hard) to fill the kettle. The little white bits that end up in the bottom of the mugs are always interesting to try to avoid.
