- 19 Jan 2005
- Oxford/Bristol
Have a read through the entries headed Entropy and Enthalpy in wikipedia.
You can boil water in a kettle and pour the boiling water into a radiator so it is possible, just not very practical and electrical heating costs more than gas heating.It really does worry me that people seem to think a kettle can replace central heating.
And even under 100% load a 500watt PSU won't always use 500 watts either if I remember right![]()
True, but then you're just using the radiator for its intended purpose anyway; to heat the room. A kettle isn't going to do that on its own.
It's not just heat. Think about the energy used to spin the case fans, kinetic. In fans, energy is also wasted as sound. It's not a significant portion of the available 500W, but it's still there.
"True, but then you're just using the radiator for its intended purpose anyway; to heat the room. A kettle isn't going to do that on its own.
It's like GSCE physics all over again, in here.
"Watt is the measurement of power?"
"Listen closely... WATT.. is the measurement of power?"
"Ahhh sir, you sneaky *******"
Blimey, 20% is pretty poor, having to use 1kw of power in order to generate only 200W, it's quite nice now many relatively affordable SMPS' now achieve 80% or even 90% efficiency without too much trouble.Incorrect.
You look at the input power drawn by a PSU and take that as 100% heat rejection. The PSU powers all of the components so they can't gain their power from thin air, just from the PSU.
Also remember that a PSU isn't 100% efficient and has losses of it's own.
In one room I was calculating heat rejection and found out from a colleagues report done previously on the old PSUs that they were less that 20% efficient. Good old school heaters that also power equipment![]()
