Tweak this spec
10 Dec 2007
Using OcUK's System Configuration (Sandybridge)
Have about £880 to spend on a system. Not logged in for free shipping.
no operating system?
ok, here's a self build
YOUR BASKET
1 x Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card £204.98
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £173.99
1 x MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £104.99
1 x Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) £99.98
1 x Lancool Dragon-Lord PC-K62 Mid Tower Case with Window - Black £87.82
1 x Antec TruePower New Modular 750W Power Supply - With FREE 3D Mark 2011 Advance £84.98
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £39.98
1 x OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £39.98
1 x Titan Fenrir Evo CPU Cooler (Socket LGA775/LGA1156//LGA1366/AMD K8/AM2/AM2+/AM3) £36.76
1 x Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £902.46 (includes shipping : £12.50).
So, it's ok as systems go, but then you can get extra goodies such as a SSD, better graphics card, and a cool case if you do it yourself. Hope I didn't miss anything and skew the results.
So basically, the upcharge is around £150 to have someone else build it for you and overclock. I'm asking about OS as you could have them install it as well :)
olivier, nope. Don't need to buy one since I get Windows 7 professional free from MSDN.
cmndr, most likely video editing and capturing (from an Intensity Pro). I was going to get the 460 for CUDA but not sure on this in applications such as CS5 (want to learn).
I forgot to say that I have all peripherals. Just need a base unit.
Thanks for recommendations and some questions.
Is the 460 not going to cut it?
I thought that Corsair was the best PSU brand? Especially the older ones.
XFX has over taken Corsair (and Enermax has always been best :p) for the 2nd best PSUs.
GTX460 will be fine for CUDA and PhysX (IF your software uses it ;))
Corsair is still one of the best PSU brand, if not THE best and most consistent, but they tend to be a little bit more expensive. Antec is also a good brand, they make their names with PSUs. Both are Seasonic based (iirc). so are XFX PSU. The HX620 that I have is legendary, and started the arms race for midrange high quality modular PSUs. They are still very much in the game.
The Corsair TX750W is a good PSU. but so is the antec. If anything, 750W is a bit over-specced for your build. A good 600W or 650W PSU will do just fine.
The 460 will be just fine, it's a great card. My point was more about value for money, but that's ok if you want to go with pre-build and not go through the hassle of building it yourself. It's just you won't get the absolute best components for the money.
